GE Nighthawk platinum bulbs which ones ?
ryangtp89
I decided to go with the GE nighthawk platinum's over the ultra stars since they don't last long for my 04 impala SS. I wanted to know what bulbs I needed for the headlights. it says low beam is 9006 and high is 9005, does that mean I need to buy 4 bulbs for the headlights ? Also I want them for my foglights which are 893's but I don't see them anywhere.
Yes the car uses 4 bulbs. If you use your hugh beams a lot then upgrade them. If not just get the lows. You may want to get HIR's instead (not to be confused with HID's).
Look up 9011 and 9012 hir bulbs. You have to trim one tab with side cutters. Easy, brighter, whiter and longer life then stock. Get from amazon.
To my knowledge there isn't a replacement or upgrade bulb for fog lights.
