gauges
backinblackgtp
gonna get a 2 pod cluster for my GTP, i know im getting a boost gauge, but what other one is easy to install, and worth getting?
Easy enough just unscrew your dummy light and put the sender or tube and coupler in there Not any harder doing a boost gauge.
Electrical for sure. You would have to run an oil line to the gauge itself if you did mechanical... mess waiting to happen
I've never had a problem, i always pick up some nylon 1/8" air brake line. The stuff they send in the kit's are garbage. This stuff is almost un-inkable and very hard to slice, but still really flexible. The easiest way is electrical sender one wire and you are done.
2 wires one to the gauge and the other to the ground
I know, the sender only has one wire going to it though. The gauge will have 4 wires coming off of it all together.
what about an aeroforce????? thats the best gauge i own....and its plug and play w/ a12volt switched wire ran to it....
i was able to hook it up in the engine, but i couldnt get it inside to the gauge? and ideas, tips or anything on how to get it inside and through which inlet?
