gauge wiring
Not sure how your cars are wired (and too lazy to go digging through the SI manual wiring diagrams to find out), but mine I just use the parking lamps fuse since its only hot when the parking lamp relay (and interior lights) are hot. Just use a add-a-circuit type deal and you're good. Can be removed with no signs it was there.
i tapped off the fog light switch. it has 12 volts when the parking lamps are engaged. 12 volt tester worked out great:D
