Gas tank
I'm not familiar with the return less systems but if the pump is functioning could you disconnect the fuel filter and run a hose from that to your gas can?
No prob. I'm going to try the Schrader valve/ jump fuel pump relay trick this weekend...P.S. I don't know how to insert a link into a post yet, so i'm glad you found it. I clicked on "fuel pump relay" in my post to you, and it went to a shopping site LOL...E.......
Mine's a weird one for sure, it's got a lot of random crap that it shouldn't. Lol
But I know that there is references for fuel filters that are inline, and not the return style, in the FSM for 04 and I've found them on RA.
Yes, 04+ doesn't have an external fuel filter. Only an in the tank filter that is not serviceable.
The 04 and 05 GT, GTP has an external fuel filter. The 05+ GXP does not have an external fuel filter like said above. also the 06+ Grand Prix does not have an external filter
Somewhat off topic but your post about spark and gas outside the engine made me think of it. I was replacing my fuel lines the other day and the needed to replace one of the nylon quick connect fitings and the parts salesman tried to tell me I could heat up the nylon lines with a lighter. I was like no I like the way my face looks. I decided to use a nylon compression fitting instead.
