Gas Leak?!
ShadowSwept
Working under the hood again and I noticed a problem with one of the fuel lines:
If I nudge it even slightly towards the UIM it sprays a stream of gas. This seems dangerous, especially with all the electronics surrounding it. I'm thinking I may have knocked it loose, but I can't seem to get it any more secure. Is this normal?
no.
Struggle for a while to replace o-rings inside the black piece, or buy a replacement connector from a parts store and press it on or get the clamp style.
What matt said^^^
Go to the parts store and get a quick connect fix kit. Word of advise, don't mess with the barbs in the kit to connect the old and new lines. Just buy a compression union for nylon-nylon lines. It won't leak, every time I used the barbed connectors... They leaked.
So it just presses on? I didn't see any o rings. Is there a way to cut the gas feed so I can fix it without spraying gasoline all over the engine?
yes.
remove fuel pump relay. then start the car.
when it dies, try turning it over for 5 seconds.
Will be lacking pressure.
Will still have fuel in it.
The barbed fittings need to be pressed in.
There is a new "easy style" fuel line repair line of products out there.
they simply slide into the existing nylon lines, then are clamped.
Well, I got a quick connect kit from Autozone, it was all they had. Looks just like the old one, with a metal tube to connect the old and new lines. Is there a way to keep it from leaking, or should I shop around for one of the clamp styles?
