Fuel pump rewire
A2tripp
Got the zzp kit.....the wire you splice in the fuse box.....do you splice both ends of the old wire to the new or just the end from the fuse box? Thanks
It came with instructions. I can't remember, but I think the other end is already in that harness which is plug n play.
Instructions say just splice into the fuse box end, but I read a thread that said splice both ends or you will have stalling issues.
Throw it away and get a real rewire from casper or racetronics. ZZP makes alot of good stuff but that is not one of them. Casper and racetronics make plug and play kits that get you much higher voltages.
In reading the instructions, only spike the piece the goes to the fuse box. After reading the instructions that say to bend the fuel pump access cover and the way they do it.. I'm not impressed.
Thank you for having me look at this, I'd go with racetronics or caspers if I ever want one.
