I tore down the top of my engine today to replace my LIM gasket and UIM & gasket. I am also replacing my lifters. When I went to disconnect the plastic fittings on the fuel line where they attach to the fuel rail, I noticed that when I moved them even slightly, a small amount of fuel leaked out of the rear connection. Can anyone tell me where I can get new "O" rings? I looked into the plastic fitting and can see that there are 2 "O" rings in there. I have read that if you try to get them from a dealer, they will not sell just the "O" rings, but only as complete fuel lines. I only need the "O" rings, not the complete fuel lines. I believe these are "Viton" ??? material.
Plus, a related question is: Can I just gently insert a small pick or something into the end of the line and carefully pry out the old "O" rings?
