Fuel injector O-rings
01gtxcoupe
Just a quick question for you guys. I am going to be changing LIM gaskets on a 2001 GT with a stock L36. While I am doing this I am going to change out the fuel injector O-rings as well. Are both rings on each injector the same size? I'm talking the side of the injector that goes into the fuel rail and the side that goes into the LIM. I want to make sure I order the correct parts.
Thanks!
if you but the magnum kit on rockauto it comes with the lower o rings, the upper / fuel rail side are not the same, you'll need to go to a part store and see what they give ya.
removal of o rings, cut them then remove, new ones oil them and roll them on wet with oil. make them wet with oil again when you push them back in the lim and clean the holes they live in as well.
