    TIPS:
FS: Used OEM Vacuum harnesses, good condition!
GoldGTP
Morning all,
During this last bout with my GTP repairs and going through my box of car goodies I stumbled across a few good sets of vacuum harnesses I have been holding onto for god knows why...
So on the chopping block they go!
1st harness is I believe for Series II motors (97-03?) and is the vacuum line that runs from the SC bypass solenoid, to the the fuel pressure regulator, to the LIM, and around the back to the MAP sensor.
GM Part number is 24508742.
Also, part 25517507 is included (the rubber boot to connect to the bypass solenoid)
ALL rubber is in excellent condition and very pliable.
BOTH "T's" are in good shape.
$SOLD$ to 01GTPgirl!
:th_divider::th_divider:
2nd harness is I believe for Series II motors also (97-03?) and is the vacuum line that runs from the passenger side of the EVAP purge valve up to the throttle body.
GM Part number is 24506665.
Again, ALL the rubber is in good condition and very pliable.
The locking side is also in good shape.
Update 1/6/2015
The following is the vacuum line that runs from the A/C (through the wire loom I believe) to the top of the SC...
Originally picked for SgtMarshall, possibly in haste, as to seeing his talk in the chat box about his line being "melted" on the rear-most manifold.
I believe this is GM Part number is 10389218.
Rubber is in good pliable shape and has no cracks, although the rubber boot appears "formed" as from being on the vacuum nipple.
$8 shipped to the right home!
This harness is I believe for Series II motors also (97-03?) and is the vacuum line that runs from the passenger side of the EVAP purge valve up to the throttle body.
Rubber elbows are not in 100% pliable shape and are starting to become "tough" (TB side appears more weathered).
A few minor cracks/splits around the opening, although very usable.
In the pics, the manipulating of the boot (mainly the TB side when I squeeze it together) is as much as the rubber wants to "give"...I wouldn't squeeze it any further...
If for whatever reason this line becomes damaged upon/during install, I will give you a 100% refund.
$7 shipped to jwach!
This line is a little more weathered than the above one, so there is a price difference...
$6 shipped to the right home!
When we were doing the valve covers on my GTP, the TS going from the purge canister broke apart. Cars got a bad vacuum leak now�� This works perfectly for me
Thanks again 01GTPgirl...
@ImNowTylerTibbets -- I will be back at pick-n-pull today or tomorrow, and if I find a good set, I'll pull them for ya!
I haven't been at my local JY in awhile. I bet there's like 50 more GP's. Which means I need to go soon. Even though it's winter, I need some quad tips.
Do you mean quad tip exhaust ends?
While I'm there I can take a look for ya?
Can this thread live on or does it need "closed" after the original item was sold?
Thanks again...
