**I know it's not a w-body but figured it's a 3800 so if I need to take it down let me know**
I'm selling my Bonneville SSE. Car is a North Carolina car and is very clean and no rust on the underside or body. Has every option including sunroof, heads up display, air valve in the truck area and 9 way power seats. Stock wheels are in nice shape with very little pitting and car does have some minor paint imperfections but is in excellent shape. You will be hard pressed to find one with low miles and clean as this is. I completely went though the car top to bottom and fixed whatever needed to be done. Car runs very strong and shifts great, plus car has a good base tune in it using Tunercats. Looking to get $4400 b/o, car is located in Rochester, NY and here's the list of new stuff on the car:
-Reman GM transmission
-fluid change dex3 last month with filter
-power steering fluid change
-coolant change
-trans-go shift kit
-New ac pump, condenser, evaporator and lines (nice and cold)
-new plugs, wires, gas filter, air filter and pcv valve
-newer upper intake plenum
-new radiator and lower hose
-new passenger side axle
-2 new motor mounts and 2 new trans mounts
-new rear frame mounts and the frame is solid, no rust
-newer front rotor/pads
-new GM fuel pump (painted the top of the gas tank with epoxy to keep it rust free)
-new rear Monroe air shocks
-reman air pump for air ride
-four newer tires, Kumho ZR rated 225/60 16
-new speakers front/rear
-repaired all water leaks
-replaced all the carpet isolation and shampooed carpet
-alignment
-2 new CV axles
-etc..
-coolant change
-trans-go shift kit
-alignment
-2 new CV axles
-etc..
