I have a 01 Pontiac Grand prix Gt 3.8L with 154000 on it ( not super charged) smelling anti freeze through my heat vents when heat is on and also noticed small amount of antifreeze in my motor mount bracket, Stuff that has already been replaced on the car: elbows, hoses, alternator, rack n pinion, power steering pump, tie rods, cv axels, tranny gasket, oil pan and gasket ( have changed gasket several times cause it keeps leaking ) tranny coolant line, now I don't know why this problem keeps happening cause I took it in and a pressure check was done and it keeps pressure and don't see any leaks when the test is performed, but when I drive it and the car comes up to temp and the heat is on that's when I start to smell the antifreeze coming through my vents in the car.
Can someone please help me with this...so frusterated
Thank you
Sammie
Thank you
Sammie
