front tires are tipped out wtf????
sic40th
just picked up a 2000 gtp with 75000 miles on it and i was looking at it from the front and i noticed that both front tires are tipped in at the top and tipped out at the bottom. it doesnt even look like half of the tire is making contact with the ground. the back tires look how they should. does anyone have a clue.
that is called camber.
the car should have some naturally with a stock alignment. how much you have cannot be measured by us. go get it checked at a competent alignment shop.
Something somewhere is shot. My 2002 GTP has shot LCA balljoints, and I went through a 40k mile tire in 5k miles.
Replaced them, had a good alignment, and whal-lah, good as new.
But like Bio said, take it to a competent alignment shop, and they can tell you exactly whats wrong, and what needs replacing.
okay thanks guys i had it sitting next to my 2002 gtp and the difference was very noticable thats how i caught it. also it pulls to the left and the tires squeel pretty bad around turns and corners would that have anything to do with. im not a suspension guy so i dont know if they are related thanks again
