Front sway bar bushings and bracket?
Akuch26
So im installing my new sway bar and bracket and I cant for the life of me get the e.s. to stop popping up no matter how I tighten them down...I've used clamps...and all sorts of other things.. the stock ones do it too. Anyone have this problem? Am I doing something?
a.) You sure you have the correct bolts
b.) You sure nothing is stripped
c.) Got a picture
A- yes reusing stock
B- not positive I know the bolts aren't but where they go in not sure. How would you know?
C- I will take some when I get home (at the brothers doing drywall)
If the endlinks are not connected first, they there should never be an issue with the brackets. There can be a problem with the bolts stripping since it's a tight area, but that's not normal if you take your time. It sounds like something else is going on.
