Ok, I've had it with this noise from the front end. I just got done installing all new struts/springs/mounts last night and what do I hear today when I drove it... a nice creeeeeaak coming from the mount area on the drivers side, just like the last set that went on which was also new. It sounds like a rubber bushing being drug across something.
I reassembled them the way the old ones came out, which was put the rubber isolator on the spring top, then a plastic insert into that, then I checked to be sure that the bottom of the mount had the 3 arrows marked "stud" actually pointing at the 3 studs. Slapped the mount on, used the proper top cup and tightened the strut rod nut down.
I also had what sounded like spring bind, like the spring couldn't rotate until I turned far enough and then it gave with a little clunk. When I removed the old struts that the car came with the last time I did the fronts, I put everything in the same order that I found it and got the same creaking noise and finally just said F-it. Now I have all new again and same thing. Is it possible that something is not in the right order/position in the assembly causing this? I've had no issues with struts on other cars, just this one for some reason.
Any helpful input would be great as I didn't blow my entire Sat. and $600 in new parts just to have the same fvcking noise I had before.
