twol8uluz
Ok, so I noticed a noise coming from the front end. Not sure how to describe it, in between a humming and a grinding. Esp when I take off from a start. (Side note, while I was doing some work about a month ago my driver side axle slippped out from the trans, causing some grease to fall out. I put the axle back in and put a new clamp on the boot...btw, the one I got...very stupid design and huge pain to do.) Not sure if this is signs of a dried out cv joint, cuz I've also had bad vibrations also. I've checked the tires, balanced, got new tires, new rims etc so that eliminates all of that. Pretty sure its an axle but not sure which one it is exactly, or another issue?
