jake91
Any ideas what this clunk is. Recently replace control arms, swaybars including poly bushings and endlinks, installed ssc springs, and tie rod ends. This happens every initial acceleration from a stop, going over speed bumps and sometimes while turning over uneven surfaces.
It sounds like someone is hitting the subframe with a hammer and its loudest on the pass side
Ive checked the endlinks, torque on all the bolts, and the calipers are tight
Only visible issue i can see is the cv axle is spewing grease
Sorry the vid is sideways
https://youtu.be/aHWkSLcMNlU
