To each their own on paint and stuff. But, a good wash, a clay bar, some beer, and a nice wax would do wonders. also, your replacement trans will f#cking hate you on 20's.1999 GP GT 279,942 miles on stock L36, trans is toast. Only upgrade is a K&N drop in filter and Alpine with bluetooth(Bose baby!). I can't wait to tear that crappy tint off and replace with 5% all around. Thinking of rattle canning it flat black. What's your opinions on lambo doors and 20's?
My 97 did this, I changed the trans fluid and filter and put another 30k miles on before I lost 4th gear. With the filter plugged there is no flow to the fluid no flow = no go in a hydraulic trans.I haven't dropped the pan but when I bought it I knew it was on it's way out. It was throwing a tcc code and shifting weird, like skipping second gear completely. I'm not a moron I check fluids like I check out women. Daily! The day it went out the pump started whining like a banshee. I pulled over checked the fluid, a little burnt but I've been adding to it the days prior. Took off and it was slipping so bad I couldn't stop because I was afraid I couldn't get it moving from a dead stop. Glad I didn't change those solenoids/tcc that would've been $100 down the drain.
you do know that bill can and more than likely will change your name if you keep call him scotty. its been a while since i was in reno/sparks im in central ca just a 4 hr drive from ya.
