found a deal on headers now i need an opinion please
natejames99gtp
found some ssac headers on cl for 100 and the guy claims they are still in good condition (is spose to send me a pic of em today) so i have been considering purchasing them and was wondering what you guys all thought about the idea? im kinda worried about breaking **** such as bolts while installing them since my car has 181000 on it. then later down the road i was thinking a pulley swap and tune but would this just be asking for my stuff to break?
Header install isn't that hard, I have 2 grand prixs which have headers, One is a set of SLP and the other are SSAC design I bought like 5 years ago when they first came out. The SSAC's will leak if you don't use exhaust compound on the joints, and toss the u clamps in the trash as they are useless. You need the same clamps they use for SLP or TOGs to prevent exhaust leaks. They run about 70 bucks for the set.
$20 fur the set if you get them from Frozenboost.com Exhaust clamps ...they are the 2.25" and 3" ones (two of each) about 1" wide clamps.
thanks guys for the info, should i worry about breaking any bolts off in the black or is that more of an issue im just imaging will happen? and it shouldn't hurt my car right? from what ive read it should help it more than anything... do i need the 02 simulator or will the self made one ive read about for 5 work fine?
it shouldnt happen. use PB blaster before hand just in case.
you cannot make one of those DIY o2 sims either. it won't work.
what do i need for gaskets and he said the bolts that he used arent in the best shape and probably shouldnt be used again so can i purchase this stuff at oriellys or is there a better place to get em. i didnt see em on zzp 3800 and wbody websites
Which bolts..the ones at the catback flange? Just pick up a couple of bolts at any hardware store. The other bolts..say holding the exhaust to the head, you can reuse yours. I've only seen 3 people break them. And I'm feeling that it was user error (like having the wrench at an odd angle)
