Fog lights inop NEED HELP
minimears
Ok so my fog lights stopped working and I'm trying to shoot the electrical to determine if the wiring, relays, and switch are the problem. I pulled the switch and found that one of the bulbs is bad and from a wiring diagram I found online that the bulb is in series with the switch. I have shot the switch checking voltages on the posts and have 12V coming in and 3.5V on one light post. Shot the wire bundle and found that I have a good ground and good supply and two other wires that are 0V and a 3.5V coming in.
First question: what voltages should I get on each? The diagram I have doesn't show what voltages Im supposed to have
2nd: is there a way to jumper the bundle to get the lights to come on, if so can someone tell me how?
I have swaped relays with each other and my horn works so I assume they are good, the switch is discontinued so if I can I want to put a new one in without going to the junk yard. If it's not the switch and not the relays is it possible to have a ground out downline and if so how can I check if I have an inop switch. Pulling my hair out over this right now and am kind of lost?
