Fog light question
01silverbullet
Hey i have a 2001 gtp and was wondering if there is any way to make it to where you can only have the fog lights on at night without the headlights. On my mustang i just switched to wires and now i can run just fogs. i wasnt sure if there is anyway we can do this the grand prixs. Not sure if anyone knows how to do this, or if it is even possible but i just thought id ask because i have HID fogs and it looks better when the headlights are off.
pull the DRL fuse, that will disable the day time running lights. (note: it may not work on your car, if it does not, come back and there is another way.)
With doing that your headlights and fogs will have to turned on manually, but its not a big deal, unless your super lazy. I have mine this way.
^This, but if you pull the DRL fuse and you start hearing a clicking under the driver side dash, you will also need to pull the plug on the module.
i just pulled the plug out of the DRL diode. there wasnt a chiming noise so i guess im ok just unplugging that. THnaks guys
