Fog Lamp Problems
ssm90GT
so the other day i realized that the fog lamps crapped out on me. The only problem is, there's no way the lamps are bad. I checked the fuse and it was fine because that was my first instinct. I even put a replacement fuse in to check it, and still nothing happened. I have a feeling that the switch is bad...has anyone had problems with this before or know anything about it?? I really have no idea how to go about getting to see if that is real issue. FYI, i dont know jack about electrical. I havent checked the lamps as that will be a grand ol' time knowing that I will get to jack up my lowered GP...if you know anything PLEASE let me know!!!
The first thing I would do is grab a multi-meter and check for voltage at the bulb connector on the fog lamp. Then you can work your way back up the system from there.
Moved this to the correct section as the Tech Tips (where this was located) is for:
"post your shortcut ideas, things that make a job easier."
