Fog bulbs
Tig
So i have an 03 LE GTP with the fancy pants, bright as hell blue fogs.
One is blown
The normal socket that you plug the fog bulb into is plugged into another plug wire that goes up into the light bracket.
I haven't had it up on a lift yet to get a 100% clear look, but something is weird and Autozone's computer says its that standard 808 or whatever foglight bulb.
These things are super bright and have a higher viewing area than my brights, but from what i've read they're stock on the LE cars
Any ideas?
Found out today, $185 for the whole unit, which is aparently has to be replaced, there isn't just a bulb
I doubt it's a sealed beam foglight. If the wiring runs into the foglight housing, see if there's a cover you can unscrew. Some bulbs like H3 have exposed quick disconnects instead of a plug-in connector, and the connector is hidden underneath another panel to keep it dry.
my fogs are H3 bulbs, hella angel eyes. they fit 130W bulbs if you trim a tab piece. i did this, but i need to rewire it because i keep blowing fuses.
