Metallistar
Ok, so I replaced the Axle Seal on the drivers side of the tranny and I thought all was ok, but now fluid is seeping out of the new seal. What else could be wrong?
It could be that the fluid is leaking out between the seal and the axle shaft. The axle shaft may be undersized, worn down, or something. You might have to replace the axle...
I would also look very close at the area around where the seal goes. There is an oring in the side cover that seals up against the channel plate, which is where the seal goes, and if the oring is going bad or wasnt installed properly fluid can slowly seep from it. The only way to replace that is by removing the side cover. I would clean it all off good with parts cleaner and make sure it is dry and look carefully where the leak is coming from, maybe snap a pic and post it up where the wet area is.
