flex plate replacement
What is the easiest way to replace the flex-plate? ive been told i can undo the tranny and the rubber mount and drop the sub-frame a little bit and then undo the motor mounts and i can make up 4 inches of room which would be enough to do. But is it recommended? HELPPPP IM NEW TO FRONT WHEEL DRIVE 3800 IVE HAD A FEW 3800 CAMAROS.
99 Pontiac Grand Prix #900 series 2 supercharged
Starter, flex to convertor, exhaust to dp, trans bracket to different, trans bolts. Everything needed to lift it out
