flex plate and torque converter
04charedcompg
is there a difference in the Hd and non Hd flex plate and torque converters? i have an L26 and it has the l26 flexplate and converter on it but i need a comp g trans, theres a long story behind this all, but thats neither here nor there. thank you in advance!
So if i have an l26 bottom end with a comp g trans which flexplate and torque converter would i run? and thanks for your info so far!
If you have an L26 or L32 motor, the flexes were dual drilled for either converter. You can also use either converter on either transmission as they do fit. Only real differences would be size and stall speed.
