The other day when first starting my car the ABS and TCS light were alternately blinking very rapidly. I did some basic research on this, which would suggest hub, wiring or EBCM. The next day the ABS light went out while driving only to come back on a few minutes later flashing rapidly then stayed on solid. I would suspect this would be indicative of the wiring that leads to the sensor. I don’t know which side since I do not posses a Tech II. Anyways I was about to inspect the wiring on both front sides when the ABS light now has been staying off more than on. At the moment ABS light is not illuminated at all. It is freezing outside and now that it seems to have fixed itself temporarily I am more than likely just going to wait until the problem pops up again or wait until it gets warmer outside and then inspect the sensor wiring very closely such as where it bends up from the control arm. Don’t fix it if it ain’t broke ‘eh?
My question, does anyone know if there a difference between a flashing or solid ABS light in our cars and what does either indicate besides there is a problem with the system?
