First Post
cn1151
Where to begin??? I bought my 97 Grand Prix SE V6 3800 for my Daughter from a “friend” :th_thumbsup-wink: for $500.00. I just wanted it to hold her over until I could repair her other car or buy her a new one. I was told there was a “fuel problem”. When I get the car home I find the Fuel pressure regulator is disconnected. Wow that was easy!!!
NOT!!! No luck the car stalled at HWY speed on my Daughter and left her stranded. It always restarted after a short rest and got her back home. At this time there were no codes. After some testing and reading a lot online (that’s how I found this sight) I replaced The MAF sensor. Then the MAP Sensor codes started popping up so I replaced that. Codes for map gone but no improvement in drivability. To shorten the story I replaced the O2 sensors the Plenum gaskets, a lot of bad Vacuum fittings, Cleaned the throttle body, replaced the bad PVC valve, the bad valve cover gaskets, power steering pump, Crank and Cam sensor, And bought some new scanner software. None of which fixed my problem. I’m getting a lot of P0171 codes. And on my last test drive I ran for a good 100 miles before it quit on me. I was looking at my scanner on the way to the service road when it started and it looked like my 02’s flat-lined as it chugged along on the HWY. When I checked the codes it gave me a P0131 and the good old P0171:th_nanana:. When I got home I removed the throttle body and looked into the plenum and it was soaked with coolant. I think that was what is causing my 02’s to go nuts and also causing my P0300 and P0171 codes and Killing my motor. Remember all the gaskets where replaced. I replaced the LIM and I’m waiting on the new UIM gasket and the Plenum. I’ll let you know how it turns out. This has been a real learning experience for me.
Update: after all that work plus some I haven’t added to my post I have found the last Gremlin in my Daughters car. When I completed the plenum I took the car out for a test drive. My STFT was looking good but my LTFT was still hanging around 16. I almost want to keep this to myself because I feel like a bone head for missing it. But the problem was the PCV O-Ring and the missing spring. I would never have found it if I didn’t go back to my repair manual and look real close at the picture. I didn’t know it had an o-ring and spring. The friend I bought it from had some work done on the car and the Mechanic must have forget to replace it. Well now my LTFT is between 4-6 which is good to me because it no longer has the P0171 code. I tried to get it inspected today and the only thing it failed for was the window tint. Which is now gone. Thanks for all the help this site is great.
Welcome to the forums!!!
WOW!!! you have accomplished a lot, and have proven to be a GREAT troubleshooter!!
they are great cars when maintained..... I hope yours gets better!!!!!!!!!!
