Finally Decided! Have some questions though?
wannabegtp
I finally decided after debating turbo, top swap, or staying na. I decided to top swap because it is cheaper than turbo and i can make good power. But i have some questions. I am going to be buy the parts over the summer and want to have headers, dp, and an intake before i top swap it. But should i install the headers and dp before i top swap it or do it all at once? Im just concerned about the low end torque loss. will it be noticeable? should i not worry about it while im getting the other parts all together? thanks
Why would you go through all the trouble of installing headers now, when all you will have to do is take them off again when you go to install the S/C heads along w/ the other top swap parts?? That's double the work. I'd wait until you have everything you need in hand (don't forget gaskets, headbolts, fluids,plugs/wires,etc) and then do it all at once.
