fans not turning on until 220
fomas1
Hell all. My fans are not turning on until 220 and turn off at 208-210 degrees . Car is stock. Any help would be great
Still almost normal.
Should be like 212 and 226 for the fans on temps with off temps are 207/223 or somthing very close.
It's not over heating by any means at 210-220º just sitting still.
Y6Evw32fNOoh5G35updsW0QRCmZAWlm2xeeYxQk54-CNCalJVWODPxb9Z5u039T-LKCd455ZF17Efd-0cjCs42VHw3CmJXuiNZtF_nro3lnOElRctFYYT-Hmcmfz4WBW9c-kUzW34AFIOxH_SgyOFZNEiWyFB746E-oBoMGNP6tXqqitXlMCL0aYdZDdkKmvMs0vTdsXBQs7mGl6fgygVsmNdIugM9FNnv-oFzrYCYE9T-IX5HrwxuLbRCAWYMasWua9dL1JoOzW7rL_Mbj5IAwqF1CwdF5n-6KnnhIs59MaY9PQrjniB7nuRjqqms3S32K0yj-ZscLo8hD_5TSvAT4AZpVM2NsFZ_NB43C_mWk0WpNQwXMDcqf_CQ1jWWa0XhCNdJQrE_Lfq0078KWynDpfm6CcxNYa56rK2CdOeBRBHNyhygW027CDOK6qShNxN-T1zWFYRbXcKwoPkxgl43kBnJEheqGNkYu_t3mHHPD8nQ5U-wA0lben37pC0W09Nwk2l_zGbE3bOngj80m61QGe6qbjf71sO44R0fuOF5W6ZYcgujtthQ29SMm5zm3WH5CsPwIIL6KOOwtggTixaNkTRDvOM3pdtTBmr8T8Ng=w478-h637-no
I wouldn't just start throwing money at it but you may have coolant flow problems.
A weak pump, really old coolant, partially blocked radiator. Also if you've never cleaned out the fins on the radiator that would be a good idea, tons of debris could be hurting it's ability to remove heat from the coolant.
Again those temps aren't bad as it's not overheating but maybe some things could be looked at.
thks pump is 5yrs old coolant is new stat is new was cooling fine when i had the zzp l36 sc kit on it stayed at constant 185. put the car back to stock na and now its doing this
