    TIPS:
F/S 2000 GTP silver mist coupe
IMPALADAKID
Hey guys. My wife is selling her GTP coupe. Purchased used two years ago next month, it has served her well. It is silver mist metallic with 179k.
Options include:
Leather
P/drivers seat
Sunroof
Bose am/fm cd
Heads up
Chrome torque stars
Over all condition:
Glass is good
Interior is near perfect
Body is solid with some scratches, and dings
Runs good
shifts good
No CEL
Mods include
Suncoast ramair hood with functioning intake
2.5 custom exhaust with stock tips.(Don't ask) :roll:
Cross drilled and slotted rotors and ceramic pads on all four corners
Recent repairs or parts:
4 General Altimax tires with nitrogen (rotated every other oil change)
Both front wheel bearings
Catalytic converter with u bend delete
Front exhaust manifold
Rear O2 sensor
Drivers axle
Both front lower control arms
Sway bar bushings
Both outer tie rod ends
Passenger rear lower control arm
EGR valve
Fuel pump
Fuel filler tube
Both serp and S/C belts
Drivers window regulator
Tune up with new AC Delco wires and plugs
Both headlamps
Valve cover gasket/wire retainer recall at dealership
New Drivers rocker panel welded in last summer.
Passed state inspection without issue.
Recent alignment
The Bad
Engine has had a knock @ idle ever since my wife purchased the car. We spent a lot of time trying to figure it out. Finally my buddy Al (V8killer) who is a GM tech,and another gm tech I know both think it is the rear bearing for the balance shaft. It has not affected performance in any way. I have replaced the oil every 4-5k with synthetic 5-30. I have yet to see any metal shavings. It has not been problem so far, Just sounds bad at idle.
Passenger front bearing seems to be getting bad again, and will need replacing very soon.
A/C delete. No working A/C
Drivers heated seat does not work.
Slight dent in rear quarter
passengers floor has just started getting wet from leaky cowl
I wanted to offer it to enthusiasts before she decides to trade it in. So she is asking $2395 or best offer. And don't be afraid to make an offer.
You can email me at [email protected] or call me 603-988-4656. Leave message or text
Car is located in Dover, NH
Thank you
Bill
The most recent pictures
Tips are stock now
How are rockers, wheel wells, gas cap, and rear strut towers? picture of the dent in the quarter? what happened to the tips in the pics? and did you take the ac out or it just doesnt work? thanks
Rockers are brand new. Wheel wells decent, gas cap and filler tube brand new this past summer. As for pics of the dent, you are looking at it in the pics. Just behind the side molding on the drivers side, just behind the door. My wife did not like the tips, and the sound. So to tone it down, I put the stock tips into the mufflers. Just unclamp and put your choice of 2.5 tips. Car will have more power, and be louder. The a/c compressor was removed when we got it. It had been replaced with a delete pully. I assume the original must have went bad. We don't use a/c so we never cared.
Here is a shot of the drivers new rocker after I welded it in and painted it this past summer.
How are the rear strut towers? do you still have these tips? and how much do you think the bearing is? and did you do pasenger side too? thank you -Zach
Rear towers are fine. Tips were cheap chrome and junky looking. They were tossed out two years ago. Bearing is $100-$150 depending on where you get one, and the quality you want to pay for. The passengers side was repaired with some metal patches as it was not as bad.
