2007 GXP ~85,000 miles.
As the title says, I am experiencing extreme inner tire wear on my right rear tire. The other three are wearing evenly. I'm thinking the alignment might be off, but the only evidence I have is the wear. Though I've also noticed that there is almost no gap from the coil mount to the tire.
In an unscientific test just using my hand to feel the gap its literally a tight fit just getting a hand between the wheel and the plate. The driver rear is also close, but has noticeably more space and the front have enough space for multiple fingers.
Any thoughts on what it could be before I throw parts at it?
Also, I know I need new tires in the rear, would I need them before an alignment or could I have the alignment checked before hand?
I'm probably going to have to space out the work so I'm trying to deal with most obvious issues first.
Edit: Bounce test doesn't show any weakness in the struts at all. Compress down and single move upward. Maybe it isn't the struts after all. Could the springs go bad?
Sent from my ASUS_Z00TD using Tapatalk
