exhaust smell
KadenGT
when im at WOT i get a strange smell in my car im sure its my exhaust (i know WOT means more exhaust flow) but why does it have a smell to it? none of my other cars had a smell when i went WOT
possibly a small leak, but then you'd have a little 'tick' at idle.
Cat could be on its way out....
But then again, everytime I mashed the gas in my GT, it'd smell that way.
1. At WOT you are likely traveling so fast that you can't smell anything but the sewage plant you are passing.
2. The exhaust should exit out the rear of the car. Unless you are WOT in reverse, or have a huge loud leak in the front...you should never be able to smell the exhaust
3. I dislike Wenly for not knowing our engine before suggesting such a thing.
4. Airflow.. see #1 and choose a different road for your WOT runs.
5. You likely need to check your valve cover gaskets. But see #1.
