Exhaust kits for 04 GTP
Captain Smiles
Hey guys, this is my first post so bear with me, I have a 04 Grand Prix GTP Comp G. Its in great shape and Im starting to want to add some mods to it.
So im here asking what would be a good cat-back exhaust system to get thats not over a grand, and gives a good V8 sounding tone. I don't mind drone at all so w/e is nice let me know.
Thanks.
welcome to the forums, as long as you have some sort of resonator it should sound good, i have the stock catback with headers and i love how the car sounds. as far as full catbacks go, i love how the borla one sounds
borla corsa or magnaflow should all be decent.
those are all stainless.
if you didn't need stainless the dynomax system is a good sounding one as well.
but for real, get headers, **** catbacks.
I will be swapping out stock headers for aftermarkets on my 04 gtp comp g too when they arrive... I would also be intersted in knowing how difficult it will be, and also if there is any good instructions for header installs on the 04= gtp's.
the mani bolts arent too bad, if anything have PB blasterr handy, its the downpipe bolts that suuuuck
you will have to take off the dogbone motor mounts and rock the engine forward to make it more accessible tho
That doesn't sound too bad i guess... With my luck ill break a manifold bolt and then the fun begins... Lol
So when doing the manifolds do you start by removing the dogbone motor mounts, pulling the engine forward, putting on the new rear manifold, rocking the engine back, putting on the front manifolds, putting on the pipe that connects the manifolds, then the downpipe? Lol im not sure how this is gonna work yet it could get interesting. :P
Well, i have already got Pacesetters, which i know have had problems with leaking, but if i rtv them really good hopefully that won't happen...
remove downpipe
remove front mani
remove crossover pipe
take off motor mounts and rock engine forward till the vavle cover hits the fans
install rear header
install crossover
rock engine back
install from header
install motor mounts
install downpipe
start up and check for leaks especially around the egr
What are some good cheep headers? What are some names and where to get um?
And what are some good home made cold air intakes?
helllloooo
btw your sig is full of win
