exhaust fell apart, need opinions/suggestions
mngtp
Last night the exhaust fell apart on our GP. It rusted/fell apart at the Y-pipe. So now there is no exhaust past the last hanger just before the Y-pipe. With no mufflers the exhaust is so loud and annoying.
Its my understanding that the cat-back exhaust flows good. I like the sound of the stock exhaust, sure it could be a little louder but oh well.
I need to fix this asap and money is a factor. I can get the exhaust from a junkyard for about $50-$70. That's the exhaust from the res flange all of the way back. Most of the exhaust looks good aside from the Y-pipe that rusted off.
So Im looking for opinions:
Do I replace the system from the res flange all of the back?
or
Do I just replace it just in front of the Y-pipe? If I go this route I would use a slightly large pipe and some clamp to sleeve the exhaust together. Would this hurt anything as far as flow/restrictions?
Could I use the "sleeve" method to delete the U bend? Can I do anything to make the exhaust a little louder than stock but still sound good?
If you have any suggestions/ideas, please share.
Thanks in advance
you will need a welder to change the Y pipe, they run around 70 to 90 bucks on ebay.
if you want for about $250 you can get a new cat back off ebay. it may only last 4 or 5 years but what you want for 250?
you forgot the 3 inch res for them fat pipes. if you go 3 inch lol
that same site has a single 3 inch set up im thinking of.
