tonglebeak
I had my tranny rebuilt (only 7 years old, thanks a lot asshole owner who owned it the previous 6 years) back at the end of december. Now that it's warm outside, I'd like to know where to go with this:
THere is a lot of noise at around 30mph. Sounds like a buttload of low-frequency resonance, and it actually gets better as speeds increase. The front wheel bearings were put on before the tranny rebuild. I've already taken the car back to the shop 3 times because they hosed the abs wiring (and I STILL need to splice the left side harness since they don't know that the sensor has to be mounted in the 6 oclock position, not 12, so it's split wide open now).
Where should I start looking to eliminate this noise that did not exist before the tranny rebuild? They had claimed it was tire noise and that it would go away with the tires rotated to the rear, and of course that did not change anything.
Also, out of curiosity, are the abs sensors swappable between bearings?
04 impala indy
04 impala indy
