EVAP Line...
black98gt
So, I swapped a L67 engine in my car because my L36 took a **** on me. Where do I put the EVAP line? I cant find out where to put it.
If your talking about where the line come out into the engine compartment the hose goes to the conector on 1 i believe not sure what you mean though
TifToGif
Thanks. Is there a way I could use rubber hose for some of the vaccum lines? Some of the hard plastic ends broke on mine.
Yea just get some tees and rubber hose if you look at my vid on my engine tear down you can see my rigged up (i know it looks bad) vac lines I had 2 of the rubber tees break so i rigged up lines with what we had in the shop the tees i had to use were huge the vac line actually went inside them except for the vacuum under the blower snout i had to use a a 1 inch section of larger line
