EVAP canister purge valve vacuum line part number
Freimuth
Does anyone know the part number for the vacuum line thatgoes from the TB to the purge valve on a 1999 GTP? I had kind of fixed it withsome Silicone vacuum line but it seems it's collapsing. Or do you know whatsize lines and fittings I would need to fix with universal stuff?
IIRC I used 1/4" line from the evap to just near the TB. Then a 1/4" to 3/8" adapter and a small piece of 3/8" hose to connect to the tb
Again..I suggest regular black hose and the same approach. unless you have the super crappy double vacuum line. Then I use line and t into it for the fpr.
