green97
I am getting a used L67 engine with 97k on it and will be installing it in my 02 very soon. Before I do it I want to address all issues with gaskets and seals while engine is out of the car.
My service manual says I need a special tool to install the rear main seal. Are there any tips or tricks on this install? Do you really need the special seal installer? Any alternative tools that can be used? Is the rear main even worth changing?
I have already purchased the following items...
felpro lower conversion gasket set, (oil pan, rear main, front/rear cover gaskets)
ac delco aluminum intake gaskets
dorman aluminum elbows
blower gaskets
egr gaskets
valve cover gaskets
valve seals
exhaust gaskets
water pump
engine and trans lower mounts
Would you replace valve seals? Please advise on anything that you would replace or freshen up while the motor was out. I also have a transgo kit with transmission currently out. Should I install the rest of the parts to it?
blower gaskets
egr gaskets
valve cover gaskets
valve seals
exhaust gaskets
water pump
