engine thud low rpms low speeds
kurupt305
got a question for yall when im in 1 or 2 not in d and im at low rpms if I take my foot off the gas and then apply it I feel a thud like the motor or tranny is engaging this also happens at low rpms in 2 not sure if its the tranny or engine mount I already changed to poly uppers thanks for the help
if your goosing the gas pedal, on and off real fast in a low gear your feeling the engine and trany trying to roll over under the hood. your mounts are probably in bad shape as well as the dog bone mounts. if you flip the bushings for the dog bones it makes the engine a bit tighter.
I already changed the dog bone mounts with polyurethane and yes that's what they feel like the only time I feel it is when the hear is in "1" or "2" at low rpms and not high im guessing it wouldn't hurt to change the mounts anyways since the car is used
i just threw a set of duralast mounts in my regal, about 40 each. im all stock so i really dont need solid anything right now. i got about 8,000 miles on them. seem to be holding up ok.
Napa has mounts that claim to be a solid rubber mount, I've heard they're like oem but I don't know for sure. You didn't post what car you have so I can't get part #'s. When I look up engine mounts for my car on advance's page, they show the hydraulic looking mount, but when they hand you the part it looks like the solid rubber mount.
They say solid rubber mounts look like this:
And hydraulic mounts look like this:
my bad buddy I have an 05 grand prix gtp non comp g
There is a writeup on how to make your hydraulic mounts solid someplace. Iirc you drill some small holes in the rubber and drain out the fluid then refill the space with window urethane.
no idea,
Westar EM2906S MOTOR MOUNTS Eng/trans Mount
I went to westar's web site and they gave a part no. of em2906, and em2906s, (s for solid) so with those numbers I found this site for you.
Please find out for sure if this part number is correct by cross referencing. I don't wont to be responsible for any wrong parts. The picture of the mount is not correct but youll see that when you go there (it says in the picture to). If you type in the part no. without the "s" it does show the correct pic for the hydraulic mount. So I do think this is the correct mount, and it seems to be cheaper at 28$
this one below is the hydraulic filled one
Westar EM2906 MOTOR MOUNTS Eng/trans Mount
that will be a great mount for you
edit:
I already found you one, part no. and everything, I just want you to double check
westar em2906S
