I am still learning about my 3800 and 99, but the question is, does your temp gauge read like mine?
I put in a new T-stat, hoses, coolant and bled everything. So I am trying to figure out if this is normal or not.
The gauge starts at 160 of course, like we all know. Mine then climbs a little higher and ends up in the range between 160 and 210.
It has plenty of heat and the coolant bottle is full too.
It just does not climb very high, but when you see the gauge starts at 160, and 190 is normal temp, it may be correct. I also have never had it in on a hot day, since I bought it a couple of months ago and it sat, as I worked on it.
Could somone verify or take a pic of their car at normal temp?
Thanks, :th_thumbsup-wink:
