TwiztdWun
Well, its not a full tear down. It is a 72K $250 junkyard engine. With the exception of the head gaskets and valve stem seals, every other gasket and seal is getting replaced. Whoever had this engine really took care of it as there is no sludge or buildup in the engine at all. No metal particles in the oil pan. Remote snake cam shows excellent hashing on the cylinder walls and not chips on the pistons.
In case you have never removed a harmonic balancer from one of these, they are very difficult. GM put some sort of reddish-orange sealant/thread locker on the bolt. It kind of looks like the stuff they used to seal the snout up to the supercharger. You can make a tool that locks the balancer in place by using a couple of the 3 slots on the balancer and locking it up against something, or, you can do what I did.... a 1" impact running 175 p.s.i. A 3/4" on 175 p.s.i. wouldn't even budge it. When I say " I ", I mean my garage monkey. I re-broke my arms where steel plates and screws are and can not do anything. So, I found someone that was willing to help, listen and learn to do the wrench turning.
