Engine swap
BankRupt
Im sorry if this is the wrong place to post but i have no idea where to put this. If someone knows anyone in minnesota that does engine swaps could you let me know. Thanks
l67 or l32 series 3 in a 01 gp gt. I was told its a benefit to go with the series 3 motor. I wouldnt be restricted to what i could put on it right?
l32 uses return less fuel rails, so you need rails off a 02 or earlier GP, as well as L67 injectors, and connectors, map harness. you need a different throttle body because the L32 is electric. also you need to rig up the evap system for the Gen V, its a bit of work but nothing extremely difficult. L67 would be a little easier because of what i just mentioned above with the L32, only advantage i see is the Gen5, better rods, etc. i would go with the L32 and do it up nice cam. Northstar tb etc, i dunno how your budget is
