DanGTP
I've noticed since I put my engine back together that it gets a rattle at about 2100 RPM and will continue to rattle up through the RPM range and back down to about 2000. I've disconnected both belts and fired it up with the same result, so I'm 99% certain it's not a pulley/pump or my blower ( I held it from moving while testing). It seems to be coming from the front bank more than the back. It's the kind of noise that a shot bearing makes when you spin it quickly. It's quiet at low RPM, but hits instantly at a certain speed. I'll try to get an audio clip of it if I can get it to pick up the noise I want.
