Thanks Pman64.
I'm just wondering what kind of labor is involved to fix this at a shop, and if left unattended what harm could be done? The leaking I was refering to when I mentioned gasket, is I think (not really mechanically inclined) coming from the supercharger gasket, because it seems the leaking already took place quite a bit and now is just damp. It runs from under the cover right next to the s/c cone, and dripped in between the spaces of the block down to inner part of the bumper. It looks like crude oil, so I'm think its either a faulty s/c gasket , but then again I think I remember seeing something in the GM service manual that says if a little puddle or leakage occurs is considered "normal" however considering it dripped all the way down the block at some point in time (now it seems to have subsided) that it may be something more serious.
I'm bringing it for my yearly inspection next 2 weeks, the car drives fine, so I hope the mechanic can figure it out. Up here in New brunswick Canada, when your not mechanically inclined and no buddies who are into cars and no friends with garages to work in, you make slow progress reading manuals, albeit I need to invest in a Haynes manual or something. Anywho, enough rambling, thanks once again for the help!
