bigpapa53023
I am in desperate need of help. Engine temp goes all the way up and then drops off suddenly to normal and the repeats. I thought that the themostat was sticking so i replaced it and it seemed fine for a day and then was back to doing the same thing. I thought that maybe i had a bad t-stat so i got another one and while i was changing it I noticed that the LIM was leaking so i replaced that and put in a new water pump as well thinking that i fo sure had this problem nailed. Took it out on a test drive tonite and what do you know IT STILL OVERHEATS SND THEN DROPS OFF. Some times it will stabilize after one or two trips up and down the scale but most of the time it just keeps doing it. Some times it goes all the way up into the red and the temp light comes on and sometimes it drops off just before that. Oil is not over full adn i dont think thats where its going. Coolant level seems stable after LIM replacement. My thought are a possibly clogged radiator. Oh and by the way lower and upper hoses do get hot. PLEASE HELP!!!
