Our motors are externally balanced.
The N/A and S/C balancers and flex plates are both different from one another due to the mass of the rods and pistons.
View topic - Illustrated Rebuilding of a L67 from a L36 : PontiacBonnevilleClub.com
For example:
My motor is a stock L36 with the L36 flex plate with an L67 balancer.
That'd suggest the front end is overbalanced compared to the back end of the crank.
Consider a rebuild with different pistons as per previous link:
Seems about normal considering its a 30 over piston.
Haven't found a mass number for the L32 rods yet.
However if I were to rebuild my motor with L32 rods and the sealed power pistons, I'd have to have the bottom end balanced.
Even as is, the bottom end is technically not 100% balanced due to the wrong balancer being installed.
Quite the curveball thrown into the whole top swap idea.
Anyone else have thoughts on this matter?
Flexplate and balancer for an internally balanced motor exist as well.
Between Meziere and Powerbond that is.
To venture in a different direction, at one point I was under the impression the S/C balancer and N/A balancer had the same balance.
More on the balancers: http://www.precisionparts.com.au/Raw/PDFs/PrecisionPartsCatalogue2009sm.pdf
As per this, there is a small counterweight and a large counterweight.
This catalog claims both N/A and S/C models use the same counterweight.
http://www.precisionparts.com.au/Raw/PDFs/Powerbond2010_NEW_US_Single.pdf
This catalog claims the L36 and L67 can use the same balancer no problem.
You get stock counterweight or no counterweight (internal balance)
This leads me to believe balancers are all the same balance, yet the flex plates are different?
Back onto flex plates:
http://www.gmforum.com/showthread.php?t=293006
Bill says.... its all okay.
So the L26 and L32 share a flex plate?
L36 Rod: 633g (rod, cap, and bolts only..no bearings)
L67 Rod: 688g (rod, cap, and bolts only..no bearings)
L36 Piston w/wristpin: 497g
L67 Piston w/wristpin: 554g
For example:
And last, here's the replacement pistons I am going to use: Federal-Mogul Sealed Power PN H871CPA 0.030 overbore.
Replacement L67 Piston w/wristpin: 560g
