Electrical system problem?
hockeybawler
So I was starting to leave my familys house from easter and when I started my car my tach, fuel, engine temp, aeroforce gauges did not work, traction control off message came on, low fuel message came on, and my cars miles read "ERROR MI". This has happened about three or four times now and I have no clue why it happens. The car will drive perfectly normal when this is going on. My radio, speedo, lights, ect will work perfectly just what I described will not work. If I shut off the car and restart it everything will go back to working again. Anyone know what could be going on? My aeroforce gauge always says my battery volts are anywhere from 14.9 to 14.2 or 3. Thanks in advance!
Remove and clean your battery cables, and clean the grounds that are on the transmission bolt and see if that takes care of it. The only other thing that comes to mind would be an ignition switch.
