Electrical Issues.. Eww.
Goldenrocket06
Going to work today the whole entire dash just shut off going down the road. Speedometer stayed going but nothing else. Get to work check fuses no bad fuses. start it up at lunch and starts right up with complete dash functions. Going home, in almost same spot, dash shuts off again. same deal as before. now pull it into garage to see wth is up and cant figure it out. go to start the car, No dash completely and my dic isnt on or working. Try turning the key to start. NOTHING. No click from the starter.. Checked fuses again and nothing once more. checked for power at every single fuse and all good. checked all relays. good. So as far as that goes, Im stumped. Any ideas would help greatly.. Also has full battery with charger on it. its an 04 gt..
sounds like a bad ground on the tranny bell housing, where the neg bat cable bolts on.
you 04 up guys got some crappy ground deal off the battery. make sure all terminals are clean and tight.
