dezebe1
So with some issues of throwing the accessory belt a couple of times on the race car I came to the conclusion that between the A/C delete bracket and the alternator, with ZZP's alt spacer bracket I have too much unsupported length and high RPM's are causing the belt to jump quite a bit. My question, is there a way to run the accessory belt with an electric water pump and not run the A/C delete pulley, there-by running a much shorter belt and keeping it from flying off at high RPM's
