EGR valve on a 1998 GTP
jfonger95
my EGR valve is shot....But the problem is i cannot find it anywhere. It is know that they are behind the throttle body, I have seen pictures and i still cannot locate it, Here is a picture..if you can help me locate it that would be greatly appreciated.2012-05-26 14.48.14.jpg
ok man your pic didnt work for me...
This is where it should be.
Ok it should be right in front of the Tranny Fluid Dip stick. Inside that little shield thing.
There is nothing in front of the tranny dip stick.. its a open gap. if you right click on the picture and open it in a new window it will work.
I still can not get your pic to work.. BUT if you look at my second pic. The little shield thing in front of the tranny dip stick. That is where the EGR SHOULD be. Mine has been deleted...
find your rear exhaust manifold. There should be a little tube that comes out the the tube on the diver-most side. follow that to the EGR. If its blocked off, you dont have it.
Ok just found this pic. the engine is being seen from the driver side of the engine bay. the shield shown lifted is the EGR shield. that thing that looks like half of a can of Beer/ soda is the EGR.
images
I dont think i have one because there is nothing there and the connector for it is just lying there(not plugged into anything) how do i approach this. is it because i have custom headers? How do i put one in there if there is no where to connect it to...as shown in the picture above.
I am wondering how you plugged the port into the manifold? Is it a big issue to clear the codes and what happens if the codes are not cleared? Thanks
